Hellobox V5 firmware release 20191109A
maeswara
Re: Hellobox V5 firmware release 20191109A
Post by maeswara » Thu Dec 05, 2019 10:01 am
Hi,good day
1- Can you provide step by step guide how to update new release firmware so newbie like me know what to do
2-Why cant just auto update through box itself,so new bie like me dont have to worry
tekmed
Post by tekmed » Sun Dec 08, 2019 1:17 pm
@gxu
Hello my friend,
I'm happy with this version, but I'd like to ask you please if some important update can be done.
WPS push button mode : I'm using a complex key, and can't write it through visual keyboard. Please is there any possibility to enable this feature ?
Youporn : I'd like to remove it completely, not just hiding avoiding bad surprises (Dump file in attachment)
Please can you help ?
Post by gxu » Mon Dec 09, 2019 2:13 am
@gxu
Hello my friend,
Sorry, I don't understand what's "WPS push button mode".
tekmed
Post by tekmed » Mon Dec 09, 2019 7:14 am
Hello
Wifi protected setup (WPS) is a protocol that helps for connecting a home wifi network.
You press a button on your router (push button) and during 2 min you can enroll a system using WPS option of the device.
https://fr.m.wikipedia.org/wiki/Wi-Fi_Protected_Setup
Regards
tekmed
Post by tekmed » Mon Dec 09, 2019 12:18 pm
@gxu
Hello my friend,
At least enabling hability of loading a WPA key from an xml or text file will be really fine.
Or even a full xml config file ready to load with all box parameters including network
What do you think?
jifat2cool
Post by jifat2cool » Sat Dec 14, 2019 1:23 am
thank you sir
Peugeot 207
Post by Peugeot 207 » Sun Dec 15, 2019 9:06 pm
gxu wrote:
Sat Nov 09, 2019 9:23 am
Release notes:
  • support t2mi
  • add scam qrcode active in Network->Scam+
  • fix some bugs
Warning:
1. backup of your channel/setting information, this version may lost your data.
2. Due to the scam server upgrade, you must use this new software to active the scam!
The old scam active will not work soon. It does not affect the scam that already actived.
Sir
Just now flashed my V5 with this firmware.
My question is:
You claimed : T2MI support
4.8E has one TP with T2MI frequency. ( 12188 H 30000 5/6 )
Have strong signal on 4.8E and this frequency , but nothing scanned.
Am I doing something wrong,?
Regards
Post by gxu » Mon Dec 16, 2019 1:44 am
Hello
Regards
Sorry, WPS has security flaw and not in our supporting plan.
Post by gxu » Mon Dec 16, 2019 1:46 am
Release notes:
  • support t2mi
  • fix some bugs
Warning:
Sir
My question is:
Regards
This TP is multistream + T2mi. Multistream is not supported with this chipset, you may try Hellobox 8.
tekmed
Post by tekmed » Mon Dec 16, 2019 7:10 am
Hello
Regards
Sorry but WPS has security flaw and not in our supporting plan.
Using a short and simple wpa key is also a security flaw.
FYI WPS security flaw is only on PIN method.
do what you want sure, but it's a pitty, I've got feature on all devices I have.
At least can you PLEASE define load feature in WIFI configuration? load can be set like channel settings from a file with ease.
