Hellobox V5 firmware release 20191016A
- machteck
Re: Hellobox V5 firmware release 20191016A
Is this supposed to open the AFN channels ?
this firm ware saport hello box v8?
Hello.
I installed the update yesterday but there is a problem with the keys.
Once you tried to insert a key (I tried this with biss & tandberg) at the momento to save it (by pressing the red button on the remote) a message saying "USB device disconnected" appears and the key is not saved into the list.
I tried, in the biss case, by entering after the bar code apperead, by pressing the blue key in the remote once the channel was loaded and also directly in the biss menu of the keys, all of them with the same result
I hope this can be solved because this version apparently works better than the previous one (with the exception of this issue)
Fortunately I was able to return to the previous state of the receiver
Regards.
Regards.
hello..can you send me the file...thank you
- machteck
With the issue of USB disconnected implies that the flash drive is not having good contact..either you use a different flash drive or you try manipulating flash drive manually to see if you can get good contact...skj1969 wrote: ↑Fri Oct 18, 2019 12:20 pmHello.
Regards.
