Release of Hellobox GX6605S ROM New version & HelloMerger V1.3
Radhit
Re: Release of Hellobox GX6605S ROM New version & HelloMerger V1.3
Powervu sir autorool!
Radhit
to powervu whether to use active code! the problem is also waiting for a long time not to open channels.
- Joey
Please record powervu stream for us,the duration more than 10 minutes.
Connect the portable hard drive
input 7791 on the powervu program
TP record will start
(DO NOT USE USB flash disk ,performance BAD.)
Radhit
mkalay
tandberg key not decrypting
- Joey
Please record tandberg stream for us,the duration more than 10 minutes.
input 7791 on the tandberg program
Umer
Hello I updated my receiver with this main file Gx6605s file... after upgrading my remote control and receiver button stop working now my recever stuck at program not exists now tell me what to do
Radhit
master, can the auto key powervu key tandberg be the same as the 2020/12/27 software, please update it so it is comfortable to use it is not coded!
- maxx
copy the firmware which work for your rx to an usb flash drive, rename the file to "auto_burn.fac", then plugin to the rx while it's ON. It will automatically install the file without having to press any button on the RC nor the panel.
Umer
this software working fine till last day updated why my remote key isn't working from last updatedmaxx wrote: ↑Fri Jan 22, 2021 7:27 amcooy the firmware which work for your rx to an usb flash drive, rename the file to "auto_burn.fac", then plugin to the rx while it's ON. It will automatically install the file without having to press any button on the RC nor the panel.
