Audio Track (Please Update)
scollrocker
Post by scollrocker » Sat Jun 27, 2020 6:06 am
Please fix at Audio Track maybe have Bug. It not working in Measat 3 at 91.5°E (A$tro). As default in English. I want to change to Malay : may. I try or test in another brand box is it working. For better, Add Language Malay or add Country Malaysia. Many User HelloBox 8 in Malaysia. HelloBox 8 now famous in malaysia.
For Subtitle is Working if i change to Malay : may. By default it in English. I want to change default as Malay : may. But is none in malay For default.
Please update new Firmware.
Re: Audio Track (Please Update)
Post by fenddick » Sun Jun 28, 2020 7:19 am
We‘ll add malaysian in the future.
Now ,pls download the Malaysian word library and use this tool to replace the language.
http://www.freedvb.com/viewtopic.php?f= ... 02a66b0e6f
robicxb
Post by robicxb » Sun Jun 28, 2020 5:53 pm
Audio Track not working some channel. Plz fix it.
scollrocker
Post by scollrocker » Thu Jul 02, 2020 1:39 pm
Please fix the bug. After change audio track, no sound can be heard. It need to click button menu and back to channel again. This step is working for audio changer bug. Please fix the bug.
[FIRMWARE 20200630]
Post by fenddick » Fri Jul 03, 2020 2:27 am
[FIRMWARE 20200630]
Please record a stream and send it to me.
scollrocker
Post by scollrocker » Fri Jul 03, 2020 11:30 am
[FIRMWARE 20200630]
Please refer my video here
https://youtu.be/l6X8sfJ5PMo
Post by fenddick » Mon Jul 06, 2020 3:03 am
[FIRMWARE 20200630]
Insert the USB flash disk, enter Media center -TS record, find the satellite and TP where the multi track program is located, select the recording time (5mins), press OK to record, and send it to us after recording.
Donno007
Post by Donno007 » Thu Aug 27, 2020 2:33 am
Hi. Any update how to solve this problem? I got same problem like you
karthi5
Post by karthi5 » Thu Aug 27, 2020 2:01 pm
For audio track issue keep 1 st audio Language and 2 nd audio change other than English then you can use select any language it will be saved
udbghdto
Post by udbghdto » Fri Feb 26, 2021 9:07 am
这个问题到现在也无法解决好,
