Hellobox 8 firmware release 20200522
Re: Hellobox 8 firmware release 20200522
Post by fenddick » Fri May 29, 2020 2:06 am
edzus1 wrote:
Thu May 28, 2020 9:01 pm
edzus1 wrote:
Fri May 22, 2020 8:15 pm
There are errors in the programming
1. Time accuracy:
   The watch is in standby mode. In 1 hour, the watch is ten minutes behind; in 11 hours, the watch is already 2 hours behind.
2. From the execution of the timer program.
  Hellobox 8 New may turn on, may not turn on by timer. According to the timer program, the specified channel or the channel that was during the transition to standby mode will turn on. When turning off by the timer, the receiver may turn off or continue to show the same channel or transmit to that channel which was before executing the timer program.
About the timer work has already been raised on the forum http://www.freedvb.com/viewtopic.php?f=25&t=18400
The problem is still not fixed.
We r working on it.
tunn
Post by tunn » Wed Jun 03, 2020 1:24 am
Plz fix
108E satellite channels don't full support.
HEVC 265
HB8
yaya82
Post by yaya82 » Wed Jul 29, 2020 9:07 am
thanks.
