Hellobox 8 firmware release 20190725
[email protected]
Re: Hellobox 8 firmware release 20190725
Post by [email protected] » Sun Aug 04, 2019 5:59 pm
hello,
I downloaded the latest version 20190725.
After upgrading via USB, Favorite channels disappeared.
l rolled back to older dump they reappeared.
is there a way to upgrade firmware via USB and maintain favorite channels?
please help
luixmax
Post by luixmax » Tue Aug 06, 2019 7:41 am
Hello everyone, AC3 + is not compatible which makes it useless for T2, a big mistake. Another bug that still inherits from hhellobox V5, when you change the audio track you lose the sound, you have to change the channel up or down to recover the sound. Very disappointed, I hope that the compatibility with AC3 + is solved or in a short time this box will be useless. Greetings.
Post by fenddick » Tue Aug 06, 2019 7:59 am
Next Version will fix this bug(audio track no sound).
AC3+ not support
luixmax
Post by luixmax » Tue Aug 06, 2019 2:53 pm
hello, the wifi signal when it has been connected for a while stops working despite the fact that in the menu it indicates that it is connected, by Lan cable there are no problems.
paisoekhant
Post by paisoekhant » Thu Aug 08, 2019 2:01 pm
T2 channel is not ok.
maicol72
Post by maicol72 » Thu Aug 08, 2019 4:33 pm
Please check 4:2:2 scrambled feed (biss). The video stream on DVBPlayer or vlc stop immediately.
With 422 free feed it's all ok
pinolo
Post by pinolo » Sun Aug 11, 2019 5:14 pm
Please set frequencies from 10.400 GHz to 12.750 Ghz to receive also some tp. on 26° E.
You can see low SR' s values (<1000)
Post by fenddick » Mon Aug 12, 2019 1:45 am
We'll working on it.
magicman
Post by magicman » Mon Aug 12, 2019 2:24 am
is it possible to add EMM's to this receiver?
Sanjayadarmadasa
Post by Sanjayadarmadasa » Mon Aug 12, 2019 1:33 pm
66e intelsat 17 and 68e intelsat 20 Sony network and discovery net work not working :o :o
Auto biss key not working
