Ask the engineer to solve the problem of frequency leakage of hellobox 8 receiving DVB-C
When hellobox8 receives DVB-C, it cannot scan frequency point programs below 474000khz. It is the same problem to replace several firmware versions. I hope engineers can improve it. Thank you!!
- wx_camera_1597322539282.jpg (1.02 MiB) Viewed 2970 times
Re: Ask the engineer to solve the problem of frequency leakage of hellobox 8 receiving DVB-C
My hellobox is working fine, plz check the DVB-C is plugged in correctly.
The same line signal is very smooth on other machines, such as H9. Hellobox8 is always stuck. Try to replace a few firmware, but it still can't be solved. Hope to repair it. Thank you!
